Grainy Footage even in good light - Page 2 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old June 24th, 2009, 12:57 AM   #16
Equal Opportunity Offender
Another issue to look at is the "sharpness" setting on the camera. The V1, for example, has it fairly high as a factory default.
If you reduce this sharpness then it should in turn reduce the prominence of any grain/noise that you pick up. (and allow more mpeg2 compression of the HDV format to be used on reproducing your target content instead of the graininess).
Andrew
