V1 / NLE Thread - Page 3 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old September 22nd, 2008, 08:36 AM   #31
Brendan,
Here is a fairly in-depth article on creating Easy-Setups, and walking you through each setting and the implications of each setting parameter.
http://provideocoalition.com/index.p..._setup_part_1/
As for the location of your easy-setups, mine are located in the following directory:
~/Library/Application Support/Final Cut Pro System Support/Custom Settings/
Where ~/ is your root directory, and not your "User" directory.
Strange that yours are not in the same directory (as this is the default). I assume that the Easy-Setups you created do show on the drop down menu when you select Easy-Setups from the final cut menu? You might also check to see if for some reason they were written to your user directory. I also assume that you are on FCP 6.04? I also assume that you have installed FCP in the default location as well.
Jeff Allen is offline   Reply With Quote
Old September 26th, 2008, 11:19 AM   #32
thanks for the tips!
Brendan Pyatt is offline   Reply
