HDMI computer monitor with V1? at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old January 7th, 2008, 02:11 AM   #1
I found this monitor:
http://www.bhphotovideo.com/c/produc..._Computer.html
It, and a few others, have HDMI input. They don't even have DVI input and require a DVI-to-HDMI cable or adapter to be used with a computer with DVI outputs. I know that computer monitors with DVI inputs don't work properly with the V1, but it seems that these monitors have image scalers from the reviews I have read.
Has anyone used one of these inexpensive monitors with the V1 and experienced something close to HD resolution and 16:9 aspect ratio?
Old January 7th, 2008, 06:36 AM   #2
Marcus, what makes you say that? I mean, I have a 24", 1920x1200 computer panel - and it works great with the computer using DVI, or with the V1 using component inputs.
Old January 8th, 2008, 01:33 AM   #3
I, and others, tried several computer monitors with DVI inputs when the V1 first came out and none displayed HD resolution. All monitors that I tested defaulted to 720x480. What I am wondering is if the HDMI monitors have the necessary image scalers to display a 1080i stream at the best possible resolution and generally the correct aspect ratio (I've read some scale to 16x10 depending on their resolution).
Marcus Marchesseault is offline   Reply
