UV filter for FX7 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old September 1st, 2007, 03:45 PM   #1
UV filter for FX7
Would you all recommend me getting a UV filter for the FX7? And if so, what brand would you get?
Thanks.
Mike
Mike Burgess is offline   Reply With Quote
Old September 1st, 2007, 04:55 PM   #2
I'm using the Hoya Super HMC Pro1 62mm UV filter; very nicely coated and fits under the lens hood. Not very expensive, highly recommened.
Old September 2nd, 2007, 02:09 AM   #3
And I use Hoya, HMC, 62 mm, UV (0), on a V1E.
Fits as well under the lens hood, so it stays on all the time
I don’t know if there is a difference to the model above
volki
Max Volki is offline   Reply With Quote
Old September 2nd, 2007, 02:11 AM   #4
Max, the difference between our models is in the number of coating layers, I believe
Old September 2nd, 2007, 02:45 AM   #5
I used a similar Hoya on my VX2100E. Now on the V1E I use a B+W filter:
"B+W 010 UV MRC SL 62mm Ultra Violet Filter (Multi-Resistant Coating - Slim Mount)" is the exact part description I have in the order. Like the Hoya mentioned above, it fits perfectly under the Sony lens hood.
It's more expensive than the Hoya equivalent, so I presume it must be better. Not comparing them side by side, I can't say whether or not I would notice the difference, but I figured that with my new HDV cam I'd get the best I could afford.
Old September 2nd, 2007, 07:07 AM   #6
Thanks for the replies. It sounds like you all are recommending that I get a UV filter for the FX7, am I right? Where did you get your filters from?
Mike
Old September 2nd, 2007, 07:46 AM   #7
Mike
Yep - generally speaking, it can protect your much more expensive camera lens both optically (UV) and mechanically, while improving the PQ marginally.
