Hvr-v1p 16.9 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old August 8th, 2007, 03:52 PM   #1
Hvr-v1p 16.9
Is this little beauty true 16.9 as i cant seem to find any info which says it is.
Apart from this....
HVR-V1P=1920 x 1080.
Recording format: 1080/50i, 576/50i (PAL)
LCD monitor: 3.5-inch Clear Photo LCD plus , approx. 211,200 dots, hybrid type, 16:9 aspect ratio
Can any one confirm it is?
Regards
Simon
Old August 8th, 2007, 06:13 PM   #2
Hi Simon. Any camera which shoots High Definition is 16:9, it's part of the spec. So with the V1 you can shoot either HDV or regular DV, depending on the settings. You can also shoot HDV and use the camera to convert to DV as you capture over firewire. All of these will give you "real" 16:9.
Old August 9th, 2007, 01:40 AM   #3
Thanks Boyd. I thought this but just needed to confirm.
Cheers
Simon
Simon Denny is offline   Reply
