Hdv hr 1000 u focus problems on low light at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old August 4th, 2010, 02:39 PM   #1
I recently filmed a wedding in a very dark place. I have a light that mounts into the camera. I was about 15 feet from the bride and right when she threw the bouquet the camera went out of focus and the focus was on auto after that ittook about 15 seconds to get focus. Has this happened to anyone else. Any tips?
Laila Silva is offline   Reply With Quote
Old August 4th, 2010, 03:42 PM   #2
Welcome to the forum Laila..
Yup happened to us in the beginning...basically the problem was our video light was not strong enough for the cam to pick up the subject and properly focus...you can try using the manual focus but if its not properly lighted, you will see horrible pixelations....the solution for us was buying a 2000 watt lighting kit that sits on a 10 ft. stand with soft box and diffuser..problem solved:)
Kren
www.verticalvideoworks.ca
Kren Barnes is offline   Reply With Quote
Old August 9th, 2010, 01:45 AM   #3
Originally Posted by Laila Silva View Post
Any tips?
When it gets realy dark (and if you don't have any additional light to add) set your camera to manual focus, zoom in completely on your subject and adjust focus accordingly and zoom out again. As long as the distance between you and your subject remains the same you can zoom in or out without going out of focus, even when the light would go out almost completely. In very dark places that's about the only way to assure that you have and keep critical focus. Never, ever trust auto focus in these situations...
Noa Put is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
