HD1000u with the 8mm look at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old December 31st, 2009, 03:37 PM   #1
Thought i'd share this with you guys...
Ken
_________________________
Vertical Video Works | Official Site
Kren Barnes is offline   Reply With Quote
Old January 4th, 2010, 10:38 AM   #2
Pretty good, but somehow I can tell it's video with a filter... I can't quite put my finger on it, but you might want to try messing around with the curves a bit more. Also, it seems a little sharper than it should be... and the depth of field is a giveaway since I'm pretty sure the frame size on the hd1000 is larger than an 8mm frame.
http://www.youtube.com/watch?v=7gVWlHn4ssg
That link should get you started, plenty of "related videos" featuring different 8mm looks.
Late December. A feature film by Matthew Overstreet & Christopher J. Adams.
Last edited by Matthew Overstreet; January 4th, 2010 at 10:43 AM. Reason: giving examples of 8mm
Matthew Overstreet is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
