Carl Zeiss Lens at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old May 17th, 2008, 09:36 AM   #1
Carl Zeiss Lens
Can some one please explain to me what the following numbers mean on the side of my lens?
1,8 / 5,4 - 54
Thanks.
Sony HDR-AX2000 • Mac Pro 8 Core w/30" Cinema Display & Final Cut Pro X
Johnnie Caraballo is offline   Reply With Quote
Old May 17th, 2008, 10:50 AM   #2
1,8 = the maximum aperture value is f/1.8 at full wide angle.
5,4 - 54 = the focal length of the lens is 5.4mm at full wide angle and 54mm at full telephoto (or in other words, it has a 10x zoom range). Hope this helps,
Old May 17th, 2008, 10:51 AM   #3
Sure does! Thank you very much!!
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
