HD 1000 filter size at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old April 5th, 2008, 05:05 AM   #1
HD 1000 filter size
The Vario - Sonnar Lens On The Hd1000, What Size Filter Thread Is It, And What Kind Of Filter Would Be The Best To Protect Lens From Dirt And Dust.
Terry Hulf is offline   Reply With Quote
Old April 5th, 2008, 10:49 AM   #2
A 37mm UV filter is all you need.
Old April 5th, 2008, 11:27 PM   #3
http://www.bhphotovideo.com/c/produc...UV_0_Haze.html
Robert M Wright is offline   Reply With Quote
Old April 6th, 2008, 04:24 AM   #4
filter size
Thanks for the help.
Terry.
Old April 12th, 2008, 10:41 PM   #5
Originally Posted by Robert M Wright View Post
I just ordered that - Should I only use it outdoors and take off when I'm inside?
Johnnie Caraballo is offline   Reply With Quote
Old April 12th, 2008, 10:51 PM   #6
I have some 43mm filters (from my Canon HV20 and Panasonic GS250) so I just got a 37mm to 43mm step up ring and use them. Also have the Canon wide angle converter which is 43mm so it makes it easy to use that well.
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old April 23rd, 2008, 08:41 AM   #7
The UV filter is safe to be used indoor and outdoors...
Maximilian Pinedo is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
