slo mo not sharp at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old March 30th, 2008, 11:14 AM   #1
slo mo not sharp
After shooting and trying I noticed the slomo is very unsharp.
I know it shoots in a lower resolution, but unless I am doing something wrong I can better use slomo in Premiere Pro CS3.
Anyone else noticing this vagueness?
Am I doing something wrong, or is is the camera as it is?
Gildo Houtekamer is offline   Reply With Quote
Old April 8th, 2008, 03:00 PM   #2
Although I have not tried this feature myself (Im actually scared I will rium the ONLY shot I have of the Bride coming down the isle) I have always been told never let the camera do ANY tricks - always do it in post.
Johnnie Caraballo is offline   Reply With Quote
Old April 17th, 2008, 06:27 PM   #3
I have the HC-3 & I think it is using the same slo-mo system. pretty much all you can do to improve the quality is to make sure that you have a lot of light. (any professional slow motion photography / videography has a TON of light.)
if you're slowing down your video 50% for long periods of time, the slow motion feature doesn't make sense.
but if you are trying to capture a single action & have it be very smooth, then you have a great feature built in. shooting 120fps is going to produce much smoother motion than slowing down video in your NLE.
here is a good example of what these cams are good for
http://youtube.com/watch?v=qpaJKBwcK_Q
but if you need resolution more than smoothness, slow the video down in post
Zach Love is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
