Moisture Condensation - Page 3 at DVinfo.net
Old June 16th, 2011, 01:34 PM   #31
Re: Moisture Condensation
How much did it cost to get the sensor replaced?
Peter Chung is offline   Reply With Quote
Old June 16th, 2011, 01:46 PM   #32
Film Gal
It was about $300
Los Angeles based Director of Photography
Jessica Gallant is offline   Reply With Quote
Old June 16th, 2011, 02:19 PM   #33
Thanks for your reply.
Old June 16th, 2011, 06:09 PM   #34
Film Gal
You're very welcome!
Old July 7th, 2011, 09:05 AM   #35
I have 3 Sony HDR-HC1's (much like the A1U). Two of my three Sony HC1's has had the moisture issue that required the cleaning of the sensor. One of the two couldn't be fixed with a simple cleaning . . . it continued to give the "moisture warning" and simply shut down each time I turned on the camera.
I recalled a posting I read some time ago that if you give a Sony Handycam a firm "slap", it often fixed Sony issues as reported by error warnings. I figured I'd try it when I had nothing to lose, since I wouldn't, at this late date, spend a ton of $ to fix the issue. To my surprise, the camera WORKED after a quick slap or two! And it continues to work . . . and this was over a year ago.
I don't advocate whacking a good piece of Sony gear . . . but if it's equipment you aren't prepared to fix otherwise, it might be worth a "shot" . . . it worked for me.
Ian
Ian Campbell is offline   Reply With Quote
Old July 7th, 2011, 09:55 AM   #36
Does this work with people?
Wayne Faulkner is offline   Reply With Quote
Old August 12th, 2011, 08:25 AM   #37
I read on a wikipedia page that the condenser triggers when there is more resistance across the sensor's contacts (which is opposite of how I would intuitively think it would work)..... but......if that is true, then could just putting some solder across the contacts on the sensor solve the moisture condensation problem ? If there is no resistance, then it would never trigger the alarm ?
Thoughts on my theory here ??
Lawrence Williams is offline   Reply With Quote
Old August 16th, 2011, 09:52 PM   #38
Bump.....come on, no one has tried the solder trick - don't you want to just crack open your camera and try it for me ;-)
I'm seriously considering it myself, the moisture condensation error is becoming a real pain in my @!#
