Thread Tools
Search this Thread
PD170 looks good..although I'm really not a Sony fan. But the HC-7...My goodness! that's some really big video...The only problem i noticed was that it had a bit more noise than expected...
Nice comparison there... G. Hayes
I'm in love... With my Panasonic AG-DVX100B. Triple M. |
They're noisy by comparison, but you're not comparing them at identical zoom (which makes some difference) but moreover, you should expect that you'll see noise in low light with the HC7 or any other HDV camcorder for that matter. You've got so many pixels crammed into such a small area, light sensitivity just goes out the window. Comparing to the *king* of low light (the PD 170) is a fair comparison for those thinking of moving from SD to HD, but compare the HC7 with other camcorders for a better sense of accuracy as to the DSP. I don't care for the 30fps override of the HC7, but I rarely shoot in really low light so won't see it much. The HC7 is mostly a crash cam and tight angle cam for us.
On the other hand, this image was captured with the same camera, very low outdoor light (wish a mini-mag or something had been on the cam, but the latitude, white balance, etc all are very broad, very solid in the blacks, no noise at all. Sorry, this wasn't shot with a PD 170 at the same time. :-) In other words, the HC7 does capture very clean video, but it needs a certain amount of light to do so. This is why the argument can be made that you just can't do HD on the cheap for everyone. If you need low light, you've got to step up to a larger size imager and better glass.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
I knew this would be the worst case scenario when I tested it. I'm going to wait I can go outdoors in daylight and do some more shooting before I have my final opinion on it.
I didn't get it to shoot in a professional capacity with it but rather as a vacation/VLOG camera. Up until this point I've been using a TRV-33 single chipper for that purpose. |
#5 |
Feed it just a tad more light, get to know the menus a bit, and I think you'll be pretty pleased. I've got two, along with a Canon HV10 and I like em both for outdoor stuff. The HDV format loves light, or you must get used to noise, one or the other. Watching the "Dog the Bounty Hunter" (shot with Z1) gets away with a LOT of noise, which surprised the heck outta me. They're shooting in dark areas while he chases the bad guy. You can occasionally see noise reduction at work, but it's still there. Those small imagers are just darn tough to please. But...the HC7 really is the best of the lot in the noise comparison, beating even much more expensive camcorders in the HDV realm.
#6 |
Hey Spot, how's the HV10 match up against the HC7?
#7 |
For most purposes, I think it's a little better. Noisy under low light, no mic input, those are the most weak points outside of the OIS. However, everything else is pretty good about it.
The IS is a totally different story. Shooting from any high-vibration platform, be it an ATV or be it a skydive mount, it's horrible. The IS doesn't fully switch off, and it bounces all over the place, giving lots of jitter and jerk in the image. I've got a short clip here
#8 |
Nice comparison shots, IMO.
I'd like to ask a general question. I have an HC1 and am wondering if the low-light noise can be worked around in any way. For example, can I use more light when shooting to get rid of the noise and then darken the footage in post? Last edited by Paul Nixon; February 14th, 2007 at 10:35 AM. |
#9 | |
I also saw no real difference with the XV color on and off. Don't get me wrong, the video was nice, but I honestly didn't think it was as solid and transparent as the HV10. One thing I should add, is it appears to me the HC5 color is better than the HC3. I don't see the same tendency to over-saturate colors in the HC5. I'm assuming the HC7 would behave the same in this respect. |
#10 |
The HC7 is definitely a lot better than the HC5 especially in the pixel area.
#11 | |
#12 |
Ken,
You caught what I wrote before I got to erase it. That post was supposed to be in the other thread. I’m sorry for the mix up. |
#13 |
More evidence that the HC7 is very noisy... I've seen low light clips of a city street by the HV10 and the noise was pretty minimal.
