Using HDV split audio out of sync? at DVinfo.net
Old January 28th, 2007, 07:34 AM   #1
After capturing with HDV split, and editing with Pro 2 and aspect hd, then downconverting to sd and burning a dvd with Encore, I noticed audio from my Sony HC1 was 4 frames off.
Audio was 4 frames before the video.
With my Z1, no problems.
All capturing was done with HDV split, using same procedure.
Anyone else noticed this?
Gildo Houtekamer is offline   Reply With Quote
Old January 28th, 2007, 07:22 PM   #2
I wouldn't blame HDVSplit, I'd probably pin the blame on Adobe Media Encoder. Sometimes it works right, sometimes it doesn't. I'd try another MPEG encoder.
Chris Harris is offline   Reply With Quote
Old January 29th, 2007, 02:22 AM   #3
Yup. The audio seems to be about 4 frames too early with hdvsplit using the hc1. Using Premieres own hdv-capture it seems to get it right.
Mpeg encoders have nothing to do with this.
Mikko Lopponen is offline   Reply With Quote
Old January 29th, 2007, 12:40 PM   #4
Tried it this afternoon.
Seems to work allright.
Thanks very much Mikko!
