Lens Hood For Wide Angle VCL-HG0737Y lens
I have been searching high and low for a lens hood for the Sony VCL-HG0737Y lens. I have not had any luck. Can you guys please point me in the right direction. Can you also please post pics, I would really like to see how the camera looks with the lens hood mounted on the camera.
Thanks in advance, Jose |
By the way, this is an excellent forum!! I bought the Sony HC1 because of the excellent reviews that were posted here. Even though I am a novice, I hope that in the future I can contribute.
JRod |
http://www.bhphotovideo.com/bnh/cont...ughType=search
it's a 77mm cavision sunshade, the diameter of the lens is 77mm so it should fit perfect. |
Thanks Jack. Do you or does anybody else have any pics with this lens hood mounted on the Sony "Y" lens?
#5 | |
Sponsor: VASST
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins Web Site: www.johnrofrano.com |
#6 |
You could also get the Cavision 3x3 Matte Box. Here is my Sony HDR-HC1, Sony VCL-HG0737Y wide angle lens, Cavision 3x3 Matte Box with 8mm rod system, and a Beachtek DXA-8 audio adapter.
http://www.geocities.com/abdullai@sb...onyHDR-HC1.jpg Here is the link to the Cavision 3x3 Matte Box: http://www.cavision.com/matteboxes/3x3hs/3x3hs.htm |
#7 | |
Thanks |
#8 |
The 3x3 matte box is rubber. It holds the french flap up fine, with no problems.
I still need to buy some 3x3 filters to test out the filter trays. I'm want to get a 3x3 Graduated Natural Density filter (Don't know which to get: ND .6 or ND .9) and a 3x3 Polarizer filter from Tiffen. Anybody know if Tiffens 3x3 filters are any good? |
#9 |
I don't like the LH77 that much (I have it). My complaints: it doesn't hold its shape well (it will often curve so it won't be a rectangle and stay in that curved shape even when you try to bend it back - it takes days for it to flatten out sometimes if you leave something heavy and flat on it), it has a gap between the lens and the shade where the screw presses in, it is only held on by that one screw, and it seems a bit thin to me, it doesn't let you be sure you are 100% parallel when you put the shade on the lens, and the screw scratches up the lens casing if you actually twist it. Plus I think the aspect ratio seems to be 4:3 instead of 16:9?
#10 |
Cavision LH77 hood + VCL-HG0737X lens: (possible?)
So if I had the Sony VCL-HG0737X, would the same wide angle hood (the Cavision 77 work?
http://www.bhphotovideo.com/bnh/cont...ughType=search I have no idea how to determine whether they fit.
http://www.imaginaryplanet.net/weblogs/idiotprogrammer/ |
