NTG-2 + A1U question at DVinfo.net
Old June 5th, 2006, 12:23 PM   #1
Is it best to use the shock mount that comes with the NTG-2 or the stock mount? I'm using the stock mount and it seems a bit loose.
Tim
Tim Cool is offline   Reply With Quote
Old June 5th, 2006, 01:45 PM   #2
Tim
Not sure about the NTG-2, but the ME-64 was also loose. You can remove the rubber piece from the Sony Mic (should come right off) and put it around the new mic. This worked like a charm for me.
Michael Stowe is offline   Reply With Quote
Old June 6th, 2006, 03:13 PM   #3
You can take the rubber off the Sony mic (as stated) or, if you sold that mic to buy a new one (like I did) then you can just buy some Velcro and use the soft side and put it around the NTG-2. I have the same mic and used that - worked great!
Adam La Prade is offline   Reply With Quote
Old June 6th, 2006, 05:39 PM   #4
You sold it? On Ebay? How much should I charge?
