Good idea to change my GL2 to HC1/HC3? - Page 2 at DVinfo.net
Old May 15th, 2006, 09:27 AM   #16
Originally Posted by Julien T. Chartier
Where did you read that the HC1/HC3 can record 3 seconds of 200fps video!?
The HC3 can do that, not the HC1.
It's 120frames-per-second for a max. of 3 seconds (NTSC version).
Only downside really is dramatically reduced resolution, but it's still a pretty clever feature.
Stu Holmes is offline   Reply With Quote
Old May 22nd, 2006, 02:06 PM   #17
So, again the low light question:
i have 2x500W halogen lamp for wedding evening.
This is just enough for XM2/GL2 to produce video with following settings:
shutter 1/50
F 1.6
Gain: 0db
So, the picture is very sharp and absolutly free of noise.
I'm afraid.
What can do in this situation the HC1? Gain up to 9db? And the picture will be noise? :(
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply With Quote
Old May 22nd, 2006, 03:17 PM   #18
Max. aperture on HC1 isn´t much worse at f1.8.
Doubt HC1 will give 9dB gain in a situ where XM2/GL2 will give 0dB.
Can't see any reason, optical or electronic for such a big gain differential.
Maybe 0.5stop = 3dB.
