flip out monitor showing pre-compression or compressed footage? at DVinfo.net
Old April 29th, 2006, 01:46 PM   #1
I'm constantly having this problem that what looks properly exposed on the HC1's flip screen monitor ends up looking underexposed in Final Cut Pro.
Could it be that the monitor is showing the HD signal before it is compressed?
Or does the monitor show the signal after it has been compressed? And if so, then I guess I should be satisfied that the image can be color corrected--because all of the information discerned on the LCD has been stored on tape?
Fischer Spooner is offline   Reply With Quote
Old April 30th, 2006, 08:14 AM   #2
That's odd. I have the opposite problem. Things that look fine on my LCD turn out overexposed. Maybe personal taste differences.
Evan Dowling
HDV 1080i
Sony HDR-HC1
Evan Dowling is offline   Reply With Quote
Old April 30th, 2006, 08:34 AM   #3
Don't rely on the LCD monitor alone, it is not a calibrated monitor. Show the histogram and use that to gauge your exposure. The viewfinder is slightly better for showing exposure (because it is less subject to ambient light + higher resolution).
Gian Pablo Villamil is offline   Reply With Quote
Old April 30th, 2006, 09:19 AM   #4
I would say that the monitor is showing pre-compressed footage. Compression and encoding on the HC1 takes up to 0.5secs and so that isn't what you're seeing on the monitor. It's probably just scaled-down, otherwise raw. The key hting with the monitor is that there's the absolute minimum of delay between real-time and what you're seeing, so the LCD monitor (and viewfinder) images need the absolute minimum of processing.
Stu Holmes is offline   Reply With Quote
Old May 2nd, 2006, 02:39 PM   #5
Fischer Spooner!
What do you think about this solution? :
http://www.rowe.at/de/images/stories...2VF_promo.html
time by time we calibrate the vf for proper exposure setting.
But the best is that you can shoot at bright sunlight without the disadvantages of a LCD.
We have tested this solution also with a HD100!
robert
Robert Leitner is offline   Reply With Quote
Old May 7th, 2006, 06:40 PM   #6
One possibility is that your Final Cut Pro monitor is not properly calibrated. It could be set too bright. Have you tried importing other footage from a different camera into Final Cut? Does it also look too bright?
Then of course the LCD on the camera can be adjusted for brightness, so if your footage consistently looks good on it, and overexposed in Final Cut, you could just turn down the brightness on your camera LCD.
Finally, the histogram is useful, but it takes some experience to read it.
Francois Camoin is offline   Reply With Quote
Old May 12th, 2006, 11:27 AM   #7
histogram?
my god, what is a histogram??!?
Old May 31st, 2006, 12:40 PM   #8
MPS Digital Studios
http://www.dvinfo.net/conf/showthread.php?t=68055
hwm
My Final Cut Pro X blog
Heath McKnight is offline   Reply
