#16 |
HC-1 "Cinema-Effect" -- Is It Any Good?
Mikko and Graham:
Thanks for the responses...So, I gather there is no desirable effect.....I will give it a shot, however...just to check it out. I appreciate it! Reilly |
#17 |
I get much better results by leaving the camera in manual mode and changing the shutter speed to 30. It's not 24, but it looks much better than using the cinema mode on HC1. Also, I have found that the HC1 tends to overexpose if left on AE. When in bright situations, I let it pick an auto exposure level and then I drop it down a few clicks. This seems to help a lot with the red problem.
Evan Dowling HDV 1080i Sony HDR-HC1 |
#18 | |
Pay attention: HC1 +2 <> A1 +2
The options: - 'WB shift' , - 'Camera Color', - 'AE Shift', - & 'Sharpness' have a -8/+8 latitude on a A1, and only a -4/+4 latitude on a HC1. (The owners of the HC1 can see what is proposed to the owners of a A1 with the menu option 'LCD color': only here the proposed scale is -8/+8 like on a A1). Consequence: if somebody mentions +1 for the 'Camera color' option on an HC1, that means '+2' on an A1... If somedody mentions -1 for the 'Sharpness' on an A1, that means quite nothing for a HC1 (because 0.5 is not possible! or you stay at +0, or you jump to -1 but that equals in fact to -2 on a A1).
Bruno (alias Koala) |
#19 |
I'm asking about the A1.
#20 |
So was there ever a conclusion on the A1? Or was it just trial and error. My A1 arrived this afternoon. Sweet little cam and ironically I was wearing a red shirt when I tested things out. Definately turned it pink. Curious what others have found to adjust this without creating havoc everywhere else.
Thanks |
