Argh! Dust on sensor. at DVinfo.net
Old April 5th, 2006, 03:21 AM   #1
Don't know how this happened, but somehow managed to get some big globs of dust on the sensor. I know it is the sensor, because the globs are perfectly in focus and bounce up and down as the image stabilizer does it's thing.
Any obvious/easy way to clean it, or does it need to go back to Sony?
Gian Pablo Villamil is offline   Reply With Quote
Old April 8th, 2006, 12:04 PM   #2
That happened to me on a motorcycle trip I just used a can of dust off worked fine after that.
Ron Little is offline   Reply With Quote
Old April 9th, 2006, 07:49 PM   #3
How did you get access to the sensor? Did you take anything apart, or poked the nozzle in through the tape hatch?
Old April 10th, 2006, 11:18 AM   #4
I just opened it up an stuck the nozzle in and dusted everything I could reach. I was on a motorcycle trip across the US and knew I would never get another chance to shoot a trip like it again. So I took the chance and it payed off. Make sure you blow out the eyepiece also. Good luck.
