I think I figured it out... at DVinfo.net
Old February 2nd, 2006, 02:39 AM   #1
It's really quite late, i should be in bed, but FCP is too addicting.
I think i figured out a way to get a better 24p look out of my HC1.
I shot in 60i with no special things going on, captured in 1080i60. Brought my clips into a 1080i50 HDV sequence. Then outputed using the DV NTSC 48Khz - 24 setting which could easily be the HDV or DVCPRO HD 1080i60 preset changed to have a 24 frame base. I'll shoot some footage later on to test this out.
Bring on the criticism... :-)
Letus35 Flip on HC1
FCP5 w/ Intel Mac Mini and Powerbook Ti G4
R.P. Cuenco is offline   Reply With Quote
Old February 2nd, 2006, 11:01 AM   #2
Do you mean the 24P setting?
Do believe that automatically deinterlaces the 50i sequence? And did you use the 16:9? What about syncing audio?
David Saraceno is offline   Reply
