Questions with regards to Sony HDR-HC1 in Final Cut Pro 5
I recently bought a Sony HDR-HC1 High Definition videocamera. I have shot some test footage and tried to import it in Final Cut Pro 5. I managed to import the footage quite easily but I have some questions.
My settings in the Audio/Video settings dialog box: Sequence preset: HDV -1080i50 Capture preset: HDV Device Control Preset: Sony HDV 100i50 FireWire Video Playback: None Audio Playback: Default The clips in the bin have the following details: Frame size: 1440x1080 Vid Rate: 25 fps Compressor: HDV 1080i50 Data Rate: 3.2MB/sec Aud Rate: 48khz Pixel aspect: HD 1440x1080 1. The bit rate that Final Cut display in the table is 3.2MB/sec. The camera is supposed to capture at a bitrate of 25mbps. 25/8 = +/- 3.2MB/sec right? 2. If I want to export one of the clips I have captured, which coded do I select? I can select "export quicktime" or "export using quicktime conversion". If I select the last one, I can select a whole list of different formats. So which one is the best to use to playback some of your footage on other computers? Please be as specific as you can be, also with regards to quality settings and other options I have. 3. The Audio/Video settings dialog box lets me choose between the following two capture presets: HDV and HDV (using Apple Intermediate Codec). Which one is the preferred option of choice by you? I really appreciate your help. |
Floris: please don't cross-post - it's against DVinfo policy.
Responses should be directed to the other copy of this thread: http://www.dvinfo.net/conf/showthread.php?t=58345 |
