"Cinema Mode" or DVFilm Maker? at DVinfo.net
Old December 29th, 2005, 05:06 AM   #1
I have an HDR-HC1 and i'm wondering what option should I take to get that 24 frame feel (whatever the hell you want to call it). Should I shoot in "Cinema Mode" or use DVFilm Maker to create a 24P stream? I'd like to know your experiences with going either route.
i.e.: Is "Cinema Mode" all that bad? Will DVFilm Maker really produce a better image or am I going to waste all my time rendering? For a $145, it better be good!
FYI: I'll be editing in FCP5 on an iMac G5 and a Power Mac G4 Dual. So if there are any other low-cost options, let me know!
also, i'm working on getting a 35mm lens adapter.
R.P. Cuenco is offline   Reply With Quote
Old December 29th, 2005, 09:21 AM   #2
RED Problem Solver
CF24 is bad. And you've burned it into your footage as you shoot, so you loose choices.
If you just want the film look, use my Film Effects plugins for FCP www.nattress.com . They work superbly well, do a great 60i to 24p, and have all the tonal and colour correction tools you need, and you can still edit in a HDV native timeline if you want.
If you want other options, or workfloes to film out etc. drop me an email with more details, or we can talk here.
Graeme
Graeme Nattress is offline   Reply With Quote
Old December 29th, 2005, 11:01 AM   #3
After I got my FX1, I immediately did a test with the Cineframe modes, namely 24 and 30. The 30 is pretty clean, and I imagine that it would be pretty clean for the HC1 as well (if it's available). The 24 is not as good -- there is definite jitter movements -- sometimes it's not noticeable but a freeze frame would show the error.
I would do a test first, shooting once in Cineframe 24 and then regular 60i. Do a still shot with a person, waving their arms. Then do a semi-fast pan along a cluttered background. Then convert the 60i using DVfilmmaker's demo, and compare the two, frame by frame.
I use Cineform ConnectHD to convert the Cineframe-24 material to a truer 24 frame -- and it looks sharp as hell. However, I don't know if Cineform is available for a Mac.
Robert Kirkpatrick is offline   Reply With Quote
Old December 29th, 2005, 03:18 PM   #4
I for one was suprised how clean the cinemode footage was from the hc1. I wouldn't use another intermediate if you don't have to. The cinema mode on the hc1 is the cineframe mode 30f found in the z1 and fx1 cameras. And I have been amazed by the professional results of the feature.
Albert Henson is offline   Reply With Quote
Old December 29th, 2005, 09:50 PM   #5
If one was to set the shutter speed at 30 then wouldn't you get "progessive" frames too?
Hse Kha is offline   Reply With Quote
Old December 29th, 2005, 11:27 PM   #6
ive been exploring more of the "digital effects" and found that setting the "flash" effect to its lowest setting gives a smoother looking feel to the footage. but when i compare it to my optura, it looks 30p-ish. it also allows manual ev or shutter setting, whereas cinema mode locks both.
i've shot with the shutter at 30 but i dont really like the motion trails it leaves. it reminds me of old tube video cameras.
unfortunately, cineform isnt available on the mac. id love to use it, but id like to keep my workflow entirely on mac.
i'll take a look at Film Effects for FCP.
ultimately, i'll be shooting a 5-7 minute film that ill hope to submit to film festivals (most likely an output to dvcpro hd or another hd tape format)
Old December 30th, 2005, 03:08 AM   #7
RED Problem Solver
Even still, I think shooting 60i and post processing gives you the most options. For instance, you can use the 60i to make nice slowmo, which shooting a faked 30p won't give you.
Graeme
Old December 30th, 2005, 01:03 PM   #8
Shoot it clean and do it in Post
I agree with Graeme. Shot it clean and do it in post. I have used Graeme's "Nattress Plug-in" Very nice I must say. Has saved crumby footage from the trash and also has enhanced clean footage to get that 24p film look. For example: if you every seen the movie "Traffic" - they have cool - warm film effects for different scenes. Nattress Plugin can do the same thing.
Save yourself time and open your options. Shoot clean video and effect it in post.
Good Luck!
www.m3films.com
Jeff Zimmerman is offline   Reply With Quote
Old December 30th, 2005, 09:05 PM   #9
to: Graeme Nattress
Hi Graeme, Just wondering if you made anything similar for us PC editors? If not, maybe you know where/what would be the closest thing for us. I just got my HC-1 a couple of weeks ago and have only had a very small amount of time to experiment with it so far. Picture quality is amazing for its size.
Thanks, PK
Graeme
Paul Kepen is offline   Reply With Quote
Old December 31st, 2005, 12:51 AM   #10
thanks guys, ill be sure to post some footage once we're off the ground and running.
Old December 31st, 2005, 03:14 AM   #11
RED Problem Solver
There are PC solutions, DV Film Maker, and the very expensive Magic Bullet for After Effects.
Graeme
Old January 2nd, 2006, 07:28 PM   #12
postproduction
I too would stick with Graeme's advice. With all the options for post production, there isn't a great need to use effects natively while shooting.
When I get my HVR-A1, I'm looking forward to see how far postproduction can be pushed...
John Grzinich is offline   Reply
