HC1 SteadyShot question at DVinfo.net
Old October 5th, 2005, 10:26 AM   #1
small question about hc1
if i use superstady shot on hc1 do i loss 25% resouloution?
becasue i can't tell the diffrence on my eyes.
Jung Kyu is offline   Reply With Quote
Old October 5th, 2005, 10:32 AM   #2
Moved here from XL H1 forum.
The "Super" in Super SteadyShot means no loss in resolution.
Old October 5th, 2005, 10:38 AM   #3
Sorry, I did send my message to awrong place... so I removed it.
Pekka
Pekka Uotila is offline   Reply With Quote
Old October 5th, 2005, 03:42 PM   #4
How does it work then?
AMD Athalon 2800 (2.08ghz) running Windows XP sp2
1GB of RAM Vegas 6.0 NLE 300+ GB hard drive space
running SATA RAID 0 With an NVIDEA Geforce FX 5600XT
http://www.dvinfo.net/conf/search.php?searchid=149990
Kevin Red is offline   Reply With Quote
Old October 5th, 2005, 07:46 PM   #5
The sensor isn't fully used for video recording. The sensor is actually 4:3. The extra edge is used for the recalculation of the stabilization system. Hence, when in photo mode, stabilization is off; utilizing the entire sensor area.
Alexander Karol is offline   Reply With Quote
Old October 6th, 2005, 01:07 PM   #6
The fact that the sensor itself is 4:3 aspect ratio is not directly relevant to how Electronic Steadyshot works.
When Elec.Steadyshot is active, it uses a border of pixels around teh actual area reserved for recording of the image, and uses this border of pixels to kinda 'float' the image. The camera 'knows' (either through analysing the "image + border area" and/or using a couple of gyrometers, how the camera has just been jiggled, and the camera then compensates and steadies the image by utilising the parts of the image that were temporarily in the border area.
As for photo mode, i am not entirely sure that EIS is disabled in this mode. Irrelevant that the photo mode captures in 4:3 aspect ratio, the same as the sensors physical aspect ratio. There's no reason why the camera couldn't use Steadyshot for the still picture. It will just be a 4:3 aspect ratio image area surrounded by a border of pixels for EIS to work, rather than a 16:9 aspect ratio image surrounded by pixels in video mode.
I could be wrong (i don't have an HC1/A1, Mr. Karol does) but i don't see any reason why EIS cannot work in photo mode and therefore i conclude that it probably DOES operate in that mode, unless you specifically switch it off.
rgds
Stu Holmes is offline   Reply With Quote
Old October 6th, 2005, 02:48 PM   #7
In ALL EIS SONY camcorders stab is disabled during PHOTO mode. I don't know about OIS ones. I don't think it would do that since OIS does not use sensor recalculation.
I have had a PC330, HC90, and now an A1 and they all disable STAB during PHOTO in order to utilize the full sensor. Well, if taking 4:3 pictures.
