HC1/A1 playback of HVR-Z1 Tapes? at DVinfo.net
Old August 16th, 2005, 05:33 PM   #1
Has anyone tried to playback HVR-Z1 HDV tapes through the HC1/A1? If it works, the HC1 might make a very convenient and affordable "dubbing/transfer" deck. Will it work?
Jim
Jim McCrain is offline   Reply With Quote
Old August 16th, 2005, 06:04 PM   #2
The manual just mentions that HDV-tapes can't be played on DV devices. It will show up blue I recall. I guess it could but I don't know anyone with a Z1 and until somebody tries it's just a wild guess.
Fredrik-Larsson is offline   Reply With Quote
Old August 17th, 2005, 04:50 AM   #3
I have played back tapes from the FX1 on the HC1 with no problems and doubbing works a treat with a 4 pin firewire lead between the two, also If you have the FX set to downconvert HDV to DV and the HC1 set to dv you can monitor your footage HDV footage on a standard TV.
Paul
Paul Rickford is offline   Reply
