HVR-A1U and Glidecam 2000 Pro Setup at DVinfo.net
Old January 13th, 2010, 09:50 AM   #1
Hello All,
I just received my Glidecam 2000 Pro last night along with my Manfrotto 577 quick release plate. Does anyone have any tips on setting it up and balancing it? I am using the standard shotgun mic that it comes with and the larger QM91D battery. If you have the same setup, how many washers are you using? I’ve noticed that once I get everything level (I’m using a small magnetic level attached to the mounting plate) that the entire rig is very fluid. What I mean by that is that the slightest touch or movement by me makes the camera start to bob up and down and back and forth. Is this normal? I do understand that using a Glidecam takes a lot of practice to get great shots, but just want to know that it’s me that sucks, not the Glidecam. Thanks!
Joel Summers is offline   Reply With Quote
Old April 8th, 2011, 09:23 PM   #2
Re: HVR-A1U and Glidecam 2000 Pro Setup
Hey Joel,
I just got a GC2000 today, and I will be using it with a A1U.
Do you have any suggestions from the past year of use?
Chris Sgaraglino
The Outdoor Life Blog | Widow Creek Photography
Chris Sgaraglino is offline   Reply
