Various questions Sony HC1 - Page 3 at DVinfo.net
Old October 9th, 2005, 12:06 PM   #31
no sorry i don't know about the FX1.
The mode needed is just rotate the silver dial one click from 'tape' mode ! takes 1 second.
that's it - just the photo mode.
Stu Holmes is offline   Reply With Quote
Old November 1st, 2005, 01:47 AM   #32
How best to capture m2t from HC1?
I need to capture the raw m2t output from my HC1 ... but I also need to be able to specify the in & out points. The reason for this is because I want to be able to capture precise clips from the tape and not go through an editing process.
I can't use Premiere Pro because it doesn't use the raw streams. I can't use ConnectHD from Cineform because you can't specify in & out points - it just captures, as does CapDVHS.
I've tried using the Media Studio Pro 8 trial but (a) it keeps on blowing up when I try to run the capture tool and (b) when I have managed to get the tool working, it doesn't look like I can specify in & out points.
Can anyone make suggestions as to how I can achieve what I need to do?
--Philip
Philip Colmer is offline   Reply With Quote
Old November 1st, 2005, 02:11 AM   #33
To get help with MSP8 go to:
http://groups.yahoo.com/group/mug-sw/
Or:
http://www.dmnforums.com/cgi-bin/dis...eadmediastudio
Danny Fye
www.dannyfye.com
Danny Fye is offline   Reply With Quote
Old November 1st, 2005, 09:45 AM   #34
Sorry - I've just re-read my original posting and it was ambiguous in the meaning of the question :-).
I wasn't specifically asking for help about MSP8 - although if it can do what I want, that is a bonus.
I was, in general, asking for advice and suggestions on any tool that will allow me to capture the m2t stream but within specific in and out points.
Thanks.
--Philip
Old November 9th, 2005, 10:47 PM   #35
HC1 read 50i HDV tapes?
I see according to this site (http://www.sonystyle.ca/commerce/ser...ductId=1001602 - look under specifications) that the HC1 can apparently read and playback 1080i50 tapes. Has anyone tried this feature? I'm thinking about using this as a deck for my Z1 and if I shoot 1080i50 HDV, it'd be nice to know that someone has tried this before. Additionally, would it be possible to monitor the 1080i50 signal (firewire out -> HC1 -> PAL/NTSC monitor)?
mg
Matthew Groff is offline   Reply With Quote
Old November 9th, 2005, 11:21 PM   #36
I believe you are correct. In fact, a lot of people have been using the HC1 as a deck. As a bonus, they get a handy vacation camcorder...a no-brainer for those with money. ;)
Alexander Karol is offline   Reply With Quote
Old November 10th, 2005, 12:04 AM   #37
Compatibility goes both ways.
Nevertheless, given the size and robustness of the HC1, i dont think it would be adequate to use it as a deck for a professional harassing type of work...
Pierre Barberis is offline   Reply With Quote
Old November 17th, 2005, 06:00 AM   #38
what is best manual setting for hc1
i use
auto exposure
color level 2up
sharpness level 1up
and i don't use white balance.
outdoor mode or auto color mode looked much better.
Jung Kyu is offline   Reply With Quote
Old November 18th, 2005, 02:51 PM   #39
Originally Posted by Jung Kyu
i use
auto exposure
color level 2up
sharpness level 1up
Do these settings work for you for regular 1080 60i or 24p conversion or both? I am very interested in running tests with my HC1 but would sure like to experiment with settings that seem to be tested and liked by the forum members. tks
Phil Hamilton
hamiltonp@sbcglobal.net
Dallas, Texas
" I'm shocked, shocked to find that gambling is going on in here! ..."
Phil Hamilton is offline   Reply With Quote
Old November 19th, 2005, 01:09 AM   #40
i use
auto exposure
color level 2up
sharpness level 1up
i put my camera HC1E on vectorscope, colorlevel +2 is very good. But sharpness +1.....factory setting is already too high, with high-contrast objects gives it already easy doubleknown...see on my test's the windpower picture.
the sites are in german, please babelfish to translate.....
http://www.fxsupport.de/hc1/hc1_2.html (color level test)
http://www.fxsupport.de/hc1/hc1_3.html (color test, windpowerpicture)
Wolfgang Winne
www.ohrwurmaudio.de www.fxsupport.de
Wolfgang Winne is offline   Reply With Quote
Old December 3rd, 2005, 04:02 PM   #41
HC1 auto white balance
hi,
please forgive this ignorant question but for all the tea in china I can not work out if the auto white balance is set every time the camera is switched on or each time recording is switched on. cheers
Hubert Hofer is offline   Reply With Quote
Old December 4th, 2005, 06:02 AM   #42
As soon as a camcorder is being switched on in camera mode, AWB tracking is active (lenscover removed) and stays active, also during recording. It will adapt the WB setting needed for the scene with a certain delay (about 10 seconds). Leaving yr can in rec. standby while walking with the lens pointed down towards e.g. the (yellow) sand will result in a blueish whitepoint shifts.
Andre De Clercq is offline   Reply With Quote
Old December 7th, 2005, 07:26 PM   #43
HC1 - Two Quick Questions
What is the minimum aperture of the lens? f8? f11?
In bright light, it seems to like the shutter speed of 125 (as opposed to 60), I guess because it feels that 60 will cause too much difraction with a smaller aperture?
Anyway if I choose manual shutter speed and set it myself, how can I know what aperture it has chosen? The only way I can find out is by shooting a clip and playing it with the Time Code Data displayed. But it is cumbersome...
Thanks.
Hse Kha is offline   Reply With Quote
Old December 8th, 2005, 06:18 AM   #44
At f11 (available?) diffraction will introduce reduced resolution with those small CCD structures. Especially when component HDV is being played it will be visible. A higher shutterspeed will introduce some more strobing which can be different (breakups?) with CMOS readout .
Old December 30th, 2005, 09:03 AM   #45
How to edit DV to HDV on HC1
I'm looking for edit software to transfer the mini DV tapes that I have from my previous Sony TR-20 to HDV on my HC1, and how to do it.I don't know if it's possible.
Thanks in advance for any help and Happy New Year.
Reinaldo Marques is offline   Reply
