HC 7 vs. HC 9
Hello All, I made the fateful error of leaving my camera bag at the airport...alone so now I no longer own a HC7. I need a fast replacement so I was about to pull the trigger on the HC9, but then I read the LANC cable thread and I wonder...anymore "upgrades" to this model over the HC7 that will give me problems?
HC7 and HC9 are virually IDENTICAL, no changes in the hardware (unless you count the black finish <G>). ONLY difference is some software changes that add a couple features, and seemed to lead to a few improvements in low light handling. And you get a nifty looking lens hood...
Grab an HC9, it'll feel just like home. PS - did you by any change try lost and found? I've been lucky... not everyone is a thief... and actually many people will try to get your stuff back to you some way! |
Yeah, I have been calling.....but this isnt a case of theft, I was a complete dummy and just left it behind as I was grabbing up my other bags outside at the curb.
My main concern is that I hope the physical size is the exact same because I use the Sony SPK-HCC water housing with my old HC7 , so I hope an HC9 will fit |
#4 | |
In checking the B&H website for info: http://www.bhphotovideo.com/c/produc...rine_Pack.html The SPK-HCC is discontinued. This is confirmed at Sony's website: http://www.sonystyle.com/webapp/wcs/...eo&SQS=SPK-HCC It appears to be replaced by the SPK-HCD which is compatible with the HDR-HC9. In looking at the online pictures of the HCC & HCD, I can't tell the difference. The Sony SPK-HCD can be found here: http://www.bhphotovideo.com/bnh/cont...eplacementLink As well as here: http://www.sonystyle.com/webapp/wcs/...Sony%20SPK-HCD |
#5 | |
The two cameras (7 & 9) are physically identical, except for a few minor cosmetic changes around the control wheel - I had the two side by side briefly just before I abandoned tape... |
