Help me make a good decision new hc-5 or used hc1 at DVinfo.net
Old June 17th, 2008, 09:13 PM   #1
Hello
my sony Hvr-A1u is gone for repair(tape stuck)
And I got to buy a camera for this friday.I just want a camera that will serve as tape deck and for use untill the A1U come back from repair.
I can buy a new HC-5 for $475 or a used HC-1 for $450
with the HC-1 I can use my other batteries, audio and shutter control,mic in,headphone in
with HC-5 brand new camera(smell good) warranty for 1 year,and upper ejection tape.
but have to buy also extra battery.
what would you choose?
Martin Labelle is offline   Reply With Quote
Old June 18th, 2008, 12:32 AM   #2
HC1 any day of the week - far better camera
Old June 18th, 2008, 02:12 AM   #3
HC1!!!! Or if you can't get one (for others in a similar dilema, as it's long discontinued) a HC7 or the brand new HC9 - essentially just a tweaked upgrade of the HC7. HC3 and HC5's were not as good for several reasons as latest Sony HC Series consumer HDV cams (from what I've read on here over the last 9 months or so)....But yes, the HC1 is a great little HDV cam - just make sure the sun's out (but you know that already with your A1 as it's essentially the same inside.)
Old June 18th, 2008, 03:26 AM   #4
And if you don't grab that HC1 for $450, please send it my way!!! I don't know you, but if you were my friend I'd slap you if you didn't grab it! Really... unless I grabbed it first.
You probably won't get an HC7/9 for anywhere close to that money either. They are "better" in some respects, but the HC1 is no slouch, as you already know. For $450, it's a no-brainer, RUN, don't walk. And as noted, you don't have to buy new accessories!
The HC5 is more or less an HC3 - lower resolution sensor, fewer features, "new" isn't necessarily "better" and this is one of those times. Don't get me wrong, I used an HC3 and liked the small form factor, but the affair ended when I put the video side by side with the HC1 and the HC7...
Old June 18th, 2008, 09:12 AM   #5
Glad to hear so much positive feedback on the HC1. I've owned this fine camera since Spring 2006. I plan to get an XH-A1 soon, but still plan to keep using my HC1.
Current Audio Equipment: two AT822 mics, Sony MZ-RH1, and KE-110CCR. What else should I get for short films and recording stand-up comedy? http://is.gd/kePy
Shahryar Rizvi is offline   Reply With Quote
Old June 19th, 2008, 12:03 PM   #6
Thank you all for the postivitive review about hc1
But I had to go for the Hc-5 because the hc-1 was in bad shape and no warranty.
And since the A1u are coming down in price I will probably get a second A1u in the fall.
