When RENDER AS using Vegas 8, which template will give you best HD video output at DVinfo.net
Old March 23rd, 2008, 05:07 PM   #1
I have a Sony HDR-HC7 and use Vegas 8 to make a video, my final video output when I play on my DVD, the vertical lines show brake into little pieces when I pan the camera, it is not smooth.
Could someone help me like:
1. What should I set on my camera so the vertical will come out smooth when I pan the camera. (or I just need to PAN fast?)
2. On Sony Vegas 8, when RENDER AS, which template will you use in able to get the best HD quality video? ie: HDV 1080 24p intermediate, NTSC DVWiderscreen 24p, etc...
Thanks very much.
--JT
John Tran is offline   Reply With Quote
Old March 23rd, 2008, 05:52 PM   #2
deinterlace
Sounds like classic interlace artifacts - or "combe" effect. Do a quick search in the Vegas or HD Editing sections using the word "deinterlace" for e.g. and you will find plenty of advice from many - me included. Some links below to get you going....
http://dvinfo.net/conf/showthread.ph...ht=deinterlace
Old March 24th, 2008, 12:39 PM   #3
Thank you very much Andy.
--JT
