Which mic will be best for my needs. at DVinfo.net
Old March 6th, 2008, 02:10 PM   #1
I am looking to purchase the Hc9 in a couple of weeks time when it is released in my country. Having the same body as the Hc7 I believe that they can share accessories. I want to use the Hc9 as a b-camera with the V1 and need a reasonable (affordable) mic. The Hc9 will mostly be used for the filming of live events. Here are the 2 mics which I have been considering:
1.)sony gun zoom mic (ecm-hgz1)
2.)sony stereo gun mic (ecm-msd1)
Any advice will be greatly appreciated
Antonie Koen is offline   Reply With Quote
Old March 7th, 2008, 03:02 AM   #2
Little Sony Mikes
Antonie, either of these mikes would work with the HC9. The HGZ1 is a hot-shoe model, that needs no battery or connecting cord. However, it is a zoom mike, that changes its directional sensitivity according to the zoom position. This might be good for some purposes, but I personally wouldn't want to have the audio changing and intensifying as I zoomed-in. You'd have to decide if you would want this feature. The MSD1 will mount in the hot-shoe, but doesn't use the connections there. It has its own battery and a stereo miniplug on a cord. This is the one of the two I would choose for my HC9, which I will also be receiving shortly. I found the MSD1 online for $50. (U.S.) and the HGZ1 for $70. These prices might vary a lot at different dealers.
I wouldn't expect these tiny mikes to be equal to larger, pro-quality types, but their size matches the camera and they are fairly low-priced. If you buy one and it doesn't pick up weak sounds well enough, then you won't have lost too much money. There is an alternative Sony mike, the ECM-MS907, which I have and will use on my HC9. It seems to still be on sale for about $80. to $100. It doesn't have a camera mount, but I cut and shortened the cord and made my own shoe-mount for it. Another version, the ECM-MS908C, has a shoe mounting and a mike holder and a shorter cord of suitable length for a camcorder. This model may be harder to find, but a couple of U.S. online dealers have it. I think it has very good performance for its size and it has a directional sector adjustment for its pickup angle. It has more sensitivity than the built-in mike on my VX2100 and the sound from it is very clean. I don't think any of these mikes come with foam windscreens, which are needed when outdoors. I cut the front half off one that was intended for a full-size mike and it fit well on my ECM-MS907.
There will be times when I will mount one of my large, 19-inch long pro mikes on the HC9. It's an XLR mike, for which I've made my own XLR to miniplug adaptor. This small camera has a metal body and hopefully, it is sturdy enough to hold this mike. Since I shoot from a shoulder-mount, I might rig up an alternate shoe for it, on a separate arm that attaches to the bottom of the mount and isn't supported by the camera. Something similar could be attached to a tripod to take the weight of a large mike off the camera.
Here's a link to an earlier message I posted, that has links to an older thread about the ECM-MS907 and to a picture and description of it on Sony's website: http://www.dvinfo.net/conf/showthread.php?t=116178
Good luck in finding the best mike and it would be helpful if you would send a message about how it performs on the HC9.
J. Stephen McDonald is offline   Reply With Quote
Old March 7th, 2008, 11:38 AM   #3
Thanks J. Much appreciated. At this stage I am leaning towards the MSD1. It seems to be a much better all rounder.
Old March 7th, 2008, 03:17 PM   #4
I'm now remembering the HGZ1 mike from several years ago. If it's the same as the one Sony was selling then, it was regarded by most people as not a very good performer and that the zoom function did not produce much in the way of effective results. If the MSD1 does the job for you, that's fine, but I expect that the MS907/MS908C would have more pickup power.
Old March 7th, 2008, 03:36 PM   #5
Have you thought about the Rode Videomic for your new HC9 as an alternative cost effective mic? You'll need a shoe adapter to convert the non-standard Sony shoe to a normal shoe (both UK and US suppliers that ship worldwide make them - very cheap.)
Many posts about this mic on here already if you're interested.
Old March 7th, 2008, 06:39 PM   #6
Andy, could you elaborate on the need for an adaptor to mount non-hotshoe mikes on the HC9? Who makes them? Actually, I've been able to mount wired and self-powered mikes in the hotshoes of my other two Sony camcorders. I cut small squares of plastic from a food container and slip them into the hotshoes, to cover and protect the electronic contacts. I temporarily stick these shields in place with a tiny drop of shoe-goo.
Old March 8th, 2008, 06:43 AM   #7
Sony Mic Shoe Adapter
I have HC1 and my understanding is that HC7 and HC9 have the same, "non-standard shoe" (i.e. a Sony proprietary one.) I use the shoe adapter sold by B. Hague on this webpage - scroll down to near the bottom. A US supplier also makes a similar low cost shoe adapter - not sure who off-hand. Note that this results in a standard cold shoe to which you can fit more or less anything you want.
http://www.b-hague.co.uk/camcorder_m...ccessories.htm
Pictures on my "rig" are also in this thread (a few posts in) showing the shoe adapter used with both the Rode Videomic and Stereo Videomic.
http://www.dvinfo.net/conf/showthrea...790#post835790
Andy Wilkinson is offline   Reply
