Sony HVR-A1U and external microphones at DVinfo.net
Old December 8th, 2007, 09:47 AM   #1
Hi, I haven't been on the forum for awhile and I'm not finding the right place to post a question I have about my Sony HVR-A1U and the use of external microphones.
I want to mic the interviewer and the interviewee in an upcoming video shoot. The interviewee will be on a wireless lav and the interviewer will be on a wired lav. I assume that if I connect the wireless in input 1, channel one, and the wired in input 2, that the wired lav in input 2 will automatically go to channel 2.
The question is, I'm not sure if both mics should be set at "mic", or if the wireless should be set to "line" and the wired to "mic". I heard somewhere that the wireless works better on "line".
Thanks.
Cindy Konits is offline   Reply With Quote
Old December 9th, 2007, 11:47 AM   #2
I believe you are correct. Wireless receivers output a line-level signal.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old December 9th, 2007, 12:27 PM   #3
Thanks.
I would think that the Sony HVR-A1U forum or the audio forum would be much better than DV Info Net Announcements forum.
M
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old December 9th, 2007, 09:33 PM   #4
Moved from Announcements to Sony HVR-A1U.
Chris Hurd is offline   Reply
