hc7 question at DVinfo.net
Old October 27th, 2007, 02:49 PM   #1
hc7 question
lcd monitor question.
i connectect the hc7 with provided cable gettings signall/ picture, but only in b/w
where is my mistake?
tes: connected the hc7 to a tv, same thing, just b/w
thanks
Karl Heiner is offline   Reply With Quote
Old October 27th, 2007, 03:17 PM   #2
Are you using component or S-video or composite?
If you're using component, component was not meant for a composite input on a TV.
If you're using S-video (just in case you have S-video), check the connectors on the cable and the TV to see if one of the pins are bent on the S-video terminal.
If you're using composite, the camera might need servicing since the composite output is always color.
Also, check the color system your TV and camera are in. If they don't match (Example: PAL on NTSC) you can't use the camera with a NTSC TV.
Old October 27th, 2007, 11:38 PM   #3
Also, if using the R/G/B cable (component), if you get two of the wires mixed up, it will be in B&W or some strange color - check those are in the right order... it's REALLY easy to mix them up behind a TV while hanging upside down <wink>!
Old October 28th, 2007, 09:53 PM   #4
well, here it is.
had enough time to try everything out and it works. i worked myself thru the settings, tried a different lcd monitor, and i am getting a color signal.
the ch7 has a a/v out and a composite out.
i guess my mistake was, the varizoom lcd has a 1/8 a/v in (1/8 plug) in front, but also a bnc (red/ white) in the back.
thanks guys for your help..
Old November 21st, 2007, 11:18 PM   #5
well, here i am again...
can't figure it out...help
hc7 connected to sony walkman700, getting a color signal. great
but i also would like to go from walkman to lcd monitor, but there i get only a b/w signal ?
anybody?
(happy thanks giving)
Old November 21st, 2007, 11:39 PM   #6
This must be a problem with your monitor. Try it on a TV.
Old November 22nd, 2007, 12:04 AM   #7
monitor is ok. been trying all variations. did a online chat with the sony help...wow no help. the guy did not know about the 700 walkman at all.
mh, i don't have one, but could i use a y cable?
