lost in translation at DVinfo.net
Old October 18th, 2007, 06:09 PM   #1
lost in translation
help....
what is the a/v out..outlet plug called ? (hc7)
i like to talk to a sales person at varizoom about a cable (if they have them)to connect their vz-tft-u monitor with my new sony hc7, but my english...<G>
thanks for the help
Karl Heiner is offline   Reply With Quote
Old October 19th, 2007, 12:27 AM   #2
there are two outputs, the "A/V out", which has right and left audio, and a composite (yellow) video signal. the other one is the component (R/G/B) out.
BOTH outs use a proprietary sony cable to conect to the camera - A/V is sort of a "D" shape, component is more or less rectangular.
Old October 19th, 2007, 12:54 AM   #3
hi dave,
well, not the hc 7.
there are the following outs, left side of cc
lanc = light blue
hdv/ dv
composit out
a/v out
head phone = dark blue
hdmi above the charger in
the pic. is on page 106
http://hdr-hc7.info/HDRHC5.pdf
i am guessing they must each their own name?
thanks
Old October 19th, 2007, 04:27 AM   #4
OK, maybe I got my composite and component mixed up...
The A/V out has the yellow plug, and the video signal is on that plug...
The composite out would be the R/G/B - three separate RCA plugs...
What inputs does your monitor support? One of the stock SONY cables should allow you to connect... The R/G/B should be the better quality picture.
Old October 19th, 2007, 01:16 PM   #5
lanc = light blue
hdv/ dv
composit out
a/v out
thanks
Dave had it exactly right.
They are in the following order, from left to right in the picture you described:
LANC
HDV/DV (Firewire)
Component (RGB Cable)
A/V (Composite Red White Yellow)
Headphone
So to answer your original question, A/V out is composite, which is probably what your monitor wants. If your monitor will accept component, use that.
Note that (if it's like the HC3) your cam will only output from the highest level output hooked up at the time. If you have cables in all the outputs, you'll only get HDMI until you disconnect that, then the component will be active, etc.
Adam Gold is offline   Reply
