Sony HVR-DR60 Uses at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old June 29th, 2007, 03:51 PM   #1
Sony HVR-DR60 Uses
Can the Sony HVR-DR60 be used with camcorders not manufactured by Sony, specifically the JVC HD110 and the Canon XH-A1?
Kevin Crockett is offline   Reply With Quote
Old January 31st, 2008, 09:23 AM   #2
Bumping this thread up as I would like to know the answer as well. I intend to use it with the Canon XL-H1 (if the unit works well with it).
Anyone?
Cheers
WeeHan
Yeo Wee Han is offline   Reply With Quote
Old February 4th, 2008, 02:57 PM   #3
Consider me interested in this answer as well. (Hope someone knows)
Get rid of the "Aspiring" in "Aspiring Filmmaker." Shoot it; you're a filmmaker. After that you're just negotiating your budget. (James Cameron paraphrased)
Alex Chamberlain is offline   Reply With Quote
Old March 1st, 2008, 12:06 PM   #4
YES....I have a HVR-DR60 and I use it all the time with my Canon XH-A1.
Canon HV20 | Sony FX1 | Canon XH-A1 | Sony XDCam EX1 | 8 Core Mac with FCP and lots of Hard Drives
Paul Kendal is offline   Reply With Quote
Old March 23rd, 2008, 12:37 PM   #5
How are you getting the files from the HVR-DR60 into FCP? With the Sony plug-in? Can you give some steps?
Brian Morris is offline   Reply With Quote
Old March 24th, 2008, 03:24 PM   #6
Plug it in and set it to "Synchro". You'll have to run tape at the same time for it to stop/start correctly with the camera. It might take a few seconds for it to start so be sure to turn on the buffer record.
You can also run it without tape in the camera but you'll have to press record on the DR60 and stop it from the DR60.
http://www.LandYachtMedia.com
Old June 27th, 2008, 09:43 AM   #7
post removed by poster.... found answer
Old September 8th, 2008, 08:48 AM   #8
How about the JVC? Can the DR60 read ProHD 24 p files?
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old October 6th, 2008, 09:40 PM   #9
I sincerely doubt it, Brian.
Most of these things are designed with specific codec(s) in mind.
Sony's website lists the HVR-DR60 as a HDV Hard Disk Recorder.
Sony Product Detail Page - HVRDR60
I think that safely rules out anything other than DV, DVCAM, and HDV.
Last edited by Bill Koehler; October 6th, 2008 at 09:44 PM. Reason: typo/format change
Bill Koehler is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
