Can V1U record 24P to the HVR-DR60? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old April 29th, 2007, 10:31 PM   #1
Hvr-dr60 & 24p
Hey guys, just a quick question. Can you record 24p to the HVR-DR60 with a Sony V1U or can you only do interlace when recording in HDV mode. Don't know if it's been answered before, tried looking all over the internet for the answer. Thanks in advance.
Wendell Alvero is offline   Reply With Quote
Old April 29th, 2007, 10:33 PM   #2
Hey guys, just a quick question. Can you record 24p to the HVR-DR60 with a Sony V1U or can you only do interlace (60i) when recording in HDV mode. Don't know if it's been answered before, tried looking all over the internet for the answer. Thanks in advance.
Old April 29th, 2007, 11:01 PM   #3
I'm guessing you didn't look all that far. These forums are pretty filled with discussions on how the V1 functions. ;-)
The 24p of the V1 is *always* packed in a 60i stream. this makes it compatible with NLE's and makes delivery much easier.
There are 'markers' or 'flags' inside the 60i stream identifying frames that are to be removed at the NLE level. When the NLE sees those flags, it "removes pulldown" from the stream, extracting the 24p information from within the 60i stream.
The DR60 records information identical to what is found on the HDV tape; 24p inside a 60i package. The DR60 functions identically to the tape mechanism, excepting that it records to non linear HDD vs linear tape.
Make sense?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 29th, 2007, 11:09 PM   #4
Got it! Thanks so much DSE, now I get the whole thing. (I was originally thinking that the workflow would have been akin to a Canon 24F system, where it does it's progressive totally diffn't from Sony). Thanks for the clear up!
Old April 29th, 2007, 11:11 PM   #5
Never mind guys, I got the answer already! thanks to DSE!
Old May 9th, 2007, 06:48 PM   #6
What's the answer???
I am curious to know.
Jerry Wiese is offline   Reply With Quote
Old May 12th, 2007, 04:44 PM   #7
Whether it's storing to tape or to a M2t file on the DR60, 24P footage is always stored as a 60i stream padded with a 3:2 pulldown (i.e. 3 progressive frames with two interlaced padding frames) which needs to be processed or used in an appropriate NLE such as Vegas 7.
Greg Quinn is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
