Any DR-60's delivered yet? - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old February 27th, 2007, 06:14 AM   #16
Hey DSE (or anyone else in the know) will this thing work with the Canon XH-A1?
Canon HV20 | Sony FX1 | Canon XH-A1 | Sony XDCam EX1 | 8 Core Mac with FCP and lots of Hard Drives
Paul Kendal is offline   Reply With Quote
Old February 27th, 2007, 08:23 AM   #17
Yes, it will work with any DV or HDV camcorder. What won't work, is that the V1 has proprietary software built in that allows the user to see "inside" the DR60 via the V1 LCD panel, so you're not having to scroll through menus on the front of the DR60.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 27th, 2007, 06:10 PM   #18
Having never used something like the DR-60 I have a few basic questions.
Can you transfer a tape that was recorded using the V1U to the DR-60 (play from the V1U and record using DR-60)?
Can you play and monitor recordings made with the DR-60 using the V1U's HDMI output (I assume the DR-60 has no outputs itself)?
Is there a way to convert an analog signal (component/composite) to an HDV stream that the DR-60 can record?
Thanks, Brian
Brian S. Nelson is offline   Reply With Quote
Old February 28th, 2007, 07:09 PM   #19
Quick question for DSE --
I just received my DR-60 and admittedly haven't read the manual. I've managed to do tapeless recording, but is it really not possible to eliminate the yellow flashing "no tape inserted" indicator on the cam?
It's quite annoying flashing right in the middle of the display...
Brent Kolitz is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
