Dropped audio frames/wrong audio at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old February 25th, 2010, 06:27 PM   #1
I am using the FX1000 with the MRC1. While recording dancing at the wedding, the last clip on the card the audio dropped out 3 times for about 40 frames (each time the duration was different & there was no dropped video frames). The last time it dropped frames the audio it recorded was from 5 minutes earlier on the same clip. Usually I also record to tape but there were only a couple of dances left so not tape backup. I tried to re-import the clip & no difference. Any ideas why this happened?
Thanks in advance for your help.
Allen
Allen Bartnick is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
