Can not get the CF recorder to work at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old January 17th, 2010, 10:34 AM   #1
Pardon my ignorance and I have looked all over the forum for this answer but have not found it so I am quite sure I am not doing something simple.
I have the S270 and just now tried shooting on CF card. Usually shoot in tape HDV. But I just can not get it to record without manually hitting the record button on the card recorder.
Read both manuals on the camera and card recorder and am at a loss how to get it to record when I hit the record button on the camera.
Could someone give me an order/settings of what to do to get the CF recorder to roll when I hit the record on the camera?
Jim Forrest is offline   Reply With Quote
Old January 17th, 2010, 05:28 PM   #2
On the MRC1k: Press the CAM LINK button on the front and look for the icon (Page 4-5), then MENU > SETTING > CAMLINK SEL > SYNCHRO (p.7-8).
On the Cam: MENU > IN/OUT REC > EXT REC CTRL > SYNCHRONOUS (p. 84).
Old January 18th, 2010, 07:52 AM   #3
Thanks.....I will print this out
Old January 19th, 2010, 04:19 PM   #4
Well I followed the directions here and still had nothing on the card unless I hit the record button on the MRC1K....so obviously there is some human error here.
Doubled checked my setting but nothing on the card...
Old January 19th, 2010, 07:06 PM   #5
Puzzling. If you've got both units set exactly as specified above, then I'm at a loss... I could be missing something, though. Perhaps others will have ideas.
If the files are fine when you use the button on the MRC to record, then we know it's not a FW problem, either ports or cable...
Adam Gold is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
