HVR-MRC1 with the FX1000 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old June 29th, 2009, 03:13 PM   #1
Okay, I sprung for the card recorder and purchased two 133x CF cards.
The only way I can make it work with the FX1000 is to run it in follow mode with a tape running simultaneously.
The book says that it will only work in follow mode with the FX1000.
Is there a setting that will make it work without a tape in the FX1000?
Also, I'm trying to figure out a way to avoid buying the $200.00 bracket that Sony has for mounting it on the trial mount of the camera. Right now, when I'm shooting interviews, I have a Rycote hot shoe extension that holds me light and my shotgun mic. If I could find a cheaper tripod mount for the MRC1K, that would be great.
Jonathan W. Hickman is offline   Reply With Quote
Old July 1st, 2009, 07:38 PM   #2
Go Cycle
Get the following bracket instead:
Bracket 1: Video Camera Bracket system for Mounting Wireless Microphone Receivers and Accessories to your camcorder
Lou Bruno
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old July 1st, 2009, 08:07 PM   #3
you can get it to work without tape by pressing the two record buttons(the record button and the one next to it) on the mrc at the same time.
Ron Wilber is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
