MRC 1 in PAL Land at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old June 10th, 2009, 07:48 AM   #1
MRC 1 in PAL Land
When I copy files from my MRC 1 into Premiere CS3 Project window, they come in with NTSC file format, which Prem. then quickly converts to PAL. I use the MRC 1 docking card reader)
I'm filming in PAL HD and I've checked the recording format which is PAL, so why do they come in with NTSC format (29.97 fps and Drop Frame Time Code)?
Cheers
Peter
Peter D. Parker is offline   Reply With Quote
Old June 14th, 2009, 10:49 AM   #2
Being so USA-centric Premiere assumes that all "unknown" video files are NTSC. Once Premiere has conformed the file then it acknowledges that the file is, indeed, PAL.
Mark Morreau is offline   Reply With Quote
Old June 15th, 2009, 02:18 AM   #3
Thanks Mark, I was beginning to think I'd some setting set to NTSC. It was weired when I saw the file come in as NTSC and then start to change to PAL.
Peter
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
