Batch renaming of m2t files from CF? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old April 11th, 2009, 02:04 AM   #1
Is there a way I can rename m2t files captured from a CF card, either before or after import to Edius? If I have one or more cards with the same start to file name (e.g. 00_) I am unable to sort the in the bin correctly, even by choosing date/time recorded. Obviously they can be renamed manually but I am looking for a faster method. Remembering to set the file name start on the Sony CF unit would have been a bonus :)
Hedley Wright is offline   Reply With Quote
Old April 11th, 2009, 03:14 AM   #2
I use this on a PC - very versatile. It will change the file extension and will give you so many other options for appending and renumbering the file name, etc;
Better File Rename for Windows: The Batch File Renamer
Cheers
John
John Purser is offline   Reply With Quote
Old April 12th, 2009, 02:31 AM   #3
Cheers
John
Thank you John
Hedley
Old April 19th, 2009, 01:24 AM   #4
Any equivalent for Mac?
Luc De Wandel is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
