HELP. CF Clips in FCP some not going in. - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old July 29th, 2008, 08:10 PM   #16
Thanks I will try old os. Where can i get the old os?
David Venturini is offline   Reply With Quote
Old July 30th, 2008, 09:53 AM   #17
I just used the OS that came with the computer. Lucky for me it was 10.5.2 but I know 10.5.3 works as well because I have it installed on my Mac Book.
Jason LeFrense is offline   Reply With Quote
Old July 30th, 2008, 07:35 PM   #18
I had to reinstall FCP after I did the OS instillation.
Old August 1st, 2008, 02:40 PM   #19
Incidentally - I just noticed what appears to be an update to the Sony plug in for Final Cut.
Click here:
http://pro.sony.com/bbsc/ssr/cat-bro...cutproTC.shtml
The version 1.1 is dated yesterday (7/31/08). for some reason, the version number doesn't seem newer. I thought it was currently AT 1.1. Maybe it was just at 1.0... Anyone know for sure?
The updates don't mention issues with clips not going in, but who knows. Maybe some of us will have better success (?).
Well, like i say. I just stumbled upon this - so maybe it's useful maybe it's not. The date of the link is what caught my eye. Plus the fact that it specifically refers to Final Cut versions 6.0.2 to 6.0.4. The last one (i believe) just said 6.0.2 and higher...
Ed Plamondon is offline   Reply With Quote
Old August 3rd, 2008, 03:36 AM   #20
Installed the 1.1 update and still no joy for me
Old August 3rd, 2008, 10:55 PM   #21
Gary -
are you having the exact same issues - nothing importing at all?
My issue has always been limited to random clips not importing. The new update appears (i stress appears) to have fixed my problems.
I am still only on FCP 6.0.3 with OSX 10.5
I think you said you're on 6.0.4.
I've held off on the update as a result of your previous posts.
Old August 4th, 2008, 03:05 AM   #22
Yes nothing at all with osx 10.5.4 with fcp 6.0.4 and the latest sony plug in.
It has never worked regardless of the osx and version of fcp on the i-mac, it did work ok on the macbook pro for a short while (1-day) when it was on 6.0.3.
I have tried going back and re-installing osx and fcp but no joy.
Old August 8th, 2008, 12:30 AM   #23
Sony update
The new update appears to have fixed importing of clips.
I'd dropped and dragged a shoot's worth of clips as the native video/HVR folder to a hard drive for further testing. These contained 3 clips of varying length that would not import into FCP. Retried them now and they worked fine, not to mention an hour of clips shot today.
So, here's hoping that problem's solved...
Mickey
Michael Power is offline   Reply With Quote
Old August 20th, 2008, 07:29 AM   #24
Having had no joy out of sony or cvp regarding the sony plug in not working I have now switched over to CLIPWRAP as my import utility.
Old September 1st, 2008, 01:59 PM   #25
Time code? with clipwrap
Are you getting time code with the clips? I downloaded the trial version and each clip begins timecode at 00.
Dan
Dan Boyd is offline   Reply With Quote
Old April 16th, 2009, 08:05 PM   #26
Hello, is this thread dead ? It's been awhile since anyone has replied...... does this mean the problem has been fixed ???? I still can't import anything into fcp and I'm still using mpeg streamclip as an alternative. This really sux balls !
http://www.dvinfo.net/conf/high-defi...-ride-1-a.html
Here is another thread i have posted on this subject if anyone care to help !
Thanks , And if i ever work out how to make it work i'll post my results.
Daniel Fisher is offline   Reply With Quote
Old December 16th, 2009, 03:23 AM   #27
I thought all my probs were solved on 10.6.2, FCP 7.01, SonyPlugin111 but alas not. I had three clips which were the tape change recording parts and none would come in correctly with "no data" as described as above. I was desperate and triedclicking the "toggle transfer button" to pause and resume the transfer as the clips stalled on the same point ea time.
Lo and behold most of one of the clips transferred! No luck on the others though...
Guess I'll have convert in MpegStream clip w/out time code.
Mark Joseph is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
