Awesome news for canon users - Page 18 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old January 15th, 2009, 10:43 AM   #256
Originally Posted by Garrett Low View Post
Brian, I'm using my MRC1 on an XL H1A so the mounting is easy. I just made a custom bracket that connects into the FS bracket that comes with the camera. It looks cool and makes the camea balance better in my opinion. For the XH A1 I would consider making a custom bracket from a thin peace of sheet metal that connected under the camera using the tripod mount. Have it extend backward and off the the right side of the camera (looking from the back) so it would sit roughly where the HD-SDI jack pack sits for the G1. Then have the MRC1 face out with the battery next to the camera. Use a 1/4" x 20 screw to secure it for underneath like it was designed.
As far as the timecode I always set to free run and non drop frame so it doesn't matter that the tape rolls after the CF starts to record. I did shoot tape and CF this last weekend and the timecodes are spot on.
I got a 1' firewire cable from Fry's electronics locally but I'm sure you can find it online somewhere. I think my cable cost $8.
Garrett
Thanks for the comments Garrett! Can you post a photo of your mount. My feeble mind can't picture what it looks like. Also which cards are you using?
http://2ndmileproductions.com
Brian Morris is offline   Reply With Quote
Old January 15th, 2009, 01:10 PM   #257
So, no more dirty heads or replaying/rewinding etc on a tape? Sounds almost too good to be true, but from reading the last 18 pages, just "GREAT" and "TRUE".
So, how do you watch footage you recorded to the card with the camera using the LCD screen? Do you select clips?
What are you guys/gals doing to back up your footage if not using tape?
Serisously, what are the best cards to use? I think space and speed and reliability are the 3 main qualities to look for in a CF card.
Derrick DeWilde is offline   Reply With Quote
Old January 15th, 2009, 01:20 PM   #258
I'll try to post some pics later tonight. I've got 1 8GB Sony UDMA CF (300X), one 8GB Sandisk Ducati, and 4 16GB Kingston (133X). All of them perform flawlessly in capturing video.
I filled all four Kingstons this last weekend during an all day dance recital shoot. I was able to get each act on one card. During the intermission I put the card full of video that I just got finished shooting into my laptop and started playing it. I was planning on just checking to make sure there were no problems and when people started seeing it they wanted to see more so I left it running during the entire intermission. It definately helped create more buzz about the DVD so I'm sure having people see will help with sales.
When I got home I just popped each card in copied the files over to my editing machine. It took approximately 8 minutes a card (there was as little over hour on each card). So over hours of footage shot and in about a hour of ingest time I was ready to edit. Unfortunately my other camera (XH A1) was recording to tape so I had 4+ hours of ingest to do on that one.
Transfer times are faster with my Sony or Sandisk cards but the Kingstons only cost me $25 each so I can't complain.
Old January 15th, 2009, 01:22 PM   #259
Will this work for me
So I have been following this thread for a while and have a few questions:
1) Will there always be dropped frames when the file splits?
2) Will the Sony wrap program fix this when it puts the files back together?
I shoot mostly recitals and concert and need the long recording time and can not afford to have any dropped audio frames. Any comments would be appreciated.
Thanks you.
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old January 15th, 2009, 01:44 PM   #260
Thanks you.
I think someone already stated that this is not an issue if set up correctly with the XH A1. If not set up correctly, I believe there is a 3 second frame drop or something I read early on. I then read that if a clip is created because of lenghth of video shot before hitting stop record, you can merge the two clips together when editing and you can see you hadn't missed a single frame.....if I read this correctly.
Old January 15th, 2009, 01:57 PM   #261
Thanks Garrett! Just FYI to everyone, B&H has a FW800 CF card reader for $59.95 and it has a $35 mail-in rebate. Lexar | Professional UDMA FireWire 800 CompactFlash | RW034-001
FYI - Rebate end today... 1/15/09
Old January 15th, 2009, 03:54 PM   #262
How does this unit work in cold weather?
Old January 15th, 2009, 04:45 PM   #263
Hey Derrick if you know where that post is where they describe the setup so there is no dropped frame I'd really appreciate it. I looked back through and couldn't find it anywhere. I tried every conceivable combination of camera and recorder settings and I still get about a 6 frame drop out of sound and the last frame of the ending file doesn't exactly match to the first frame of the new file.
Jonathan, I too shoot a lot of recitals and shows and have the camera running continuously for up to two hours. Before I had to worry about making a quick tape change every hour. Now, I'm waiting for 64GB CF cards (hope the Sony unit will support them that big) so I can go 4 hours. I do also capture to tape simultaneously both as a backup (I'm a huge believer in redundancy) and for archive. I figured I'd just save the parts where I have tape changes to DVD so I will have a complete archive copy.
I always shoot with a minimum of two cameras and capture sound via a mixer and laptop. So the couple of frames dropped between files is no deal breaker for me but it would be nice to just be able to pull the files into my NLE an connect them end to end.
Old January 15th, 2009, 05:55 PM   #264
Only few things are holding me back from pulling the trigger :
1) That drop in audio while the CF reader splits into another file due to the file system limitation. Doing long ceremonies, having a drop in audio during an important part would suck. Then I'd have to break out the tape archive and grab that piece. Derrick, what would be "the correct setup"?
2) Not sure how I would capture HDV -> ProRes in FCP using these clips.
3) Ger mentioning of the unit erroring out with certain cards. I guess I'd have to spring for the more expensive cards.
4) Is this thing hot swappable? Like when a card fills up, can I just swap in another card while the tape is recording?
It's either the CF recorder or buy a Switz light and have some pocket money for next month..lol.
Randy Panado is offline   Reply With Quote
Old January 15th, 2009, 05:59 PM   #265
Hi Randy,
I haven't tried swaping cards out when the tapes running. I'll have to try that tonight.
Garrett.
Old January 15th, 2009, 06:24 PM   #266
Thanks for the heads up!
Old January 15th, 2009, 06:41 PM   #267
Hi Randy,
Garrett.
Sounds good! Please try these two methods :
1) When data fills up and unit stops recording.
2) Mid write of the data (unit hasn't stop recording).
I suspect number 2 will be a big failure but am curious as to how number 1 will do.
Thanks for volunteering Garret!
Old January 15th, 2009, 10:08 PM   #268
How much stopping and starting are you doing?
A lot.
Basically you need to give the unit time to write the file to the card before you press rec again. You'll get away with it most of the time but get caught now and again.
now i actually just keep it recording to avoid this problem.
Ger Griffin is offline   Reply With Quote
Old January 15th, 2009, 10:10 PM   #269
You could have done that on the journey home with the unit. No pc required for capture any more! Just play the tape on the cam and push REC (both buttons) on the unit.
Old January 15th, 2009, 10:23 PM   #270
I have 3 of these units with my 3 A1 Cameras. At the beginning I was not sure of the investment, Now I'm thinking I did the best. We are shooting multicamera weddings and we are saving a significant time in capturing tapes.
So far no error with CF transcend 133x 32G cards. Changing the tape after an hour It was no creating any significant drop out in my audio.
I let my tape finish and the unit still recording. I change the tape and then I hit record. The tape started recording and the unit instantly creates a new file. on post I did not see any big drop out.
Jose Ortiz is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
