Mixing it up in XDCAM HD 24p Timeline at DVinfo.net
Old June 24th, 2007, 03:59 PM   #1
I am shooting one client's project in 24p XDCam HD, editing using Final Cut. At times I might want to throw in some 1080i HDV footage, maybe also some 1080i footage from XDCam HD, and keep a 24p look.
The result isn't bad if I just drag the 1080 into the 24p timeline -- but it could look a bit smoother. Any ideas on how to best integrate? Would some type of effect software help?
Bill Weaver
Across Borders Media / Media that Matters
Bill Weaver is offline   Reply With Quote
Old June 24th, 2007, 09:56 PM   #2
Update to FCS2. It can mix different formats/codecs on the same timeline.
My Work: nateweaver.net
Old June 25th, 2007, 12:00 PM   #3
Mixing it up
Thanks, Nate, I will..
But what I want to do is preserve the 24p look and feel..... Any ideas?
Bill Weaver
Old June 25th, 2007, 02:43 PM   #4
If you lay both the 60i and 24p into a 60i/35/mbs XDCAM HD timeline, you'll retain the look of both formats, with the exception that the 24p will have an incorrect pulldown applied (but it will look 90% the same).
If you're talking about making the 60i look like 24p and then mixing, you just have to do a conversion on the 60i with a Nattress plug or something...which would take eons unfortunately.
Nate Weaver is offline   Reply
