February 1st, 2007, 04:27 PM | #16 | |
No doubt broadcast cameras will use flash memory, however, it remains to be seen if they'll use consumer memory cards. At present the trend is towards high data rates for HD, which would point to needing larger memory storage than most consumers require, plus higher quality control. |
February 1st, 2007, 05:42 PM | #17 | |
February 1st, 2007, 06:00 PM | #18 | |
But the advantage of XDCAM is that it is available NOW. Infinity is still a couple of months away, though apparently the delay was due to a change of chip. I believe it will now ship with a 1920x1080 CMOS chip. And hence get over some of the power/weight issues which have led to some criticism. It's also worth mentioning that the max size currently available for P2 is only 8GB, compared to 16GB for Compact Flash. Hopefully RevPro will have a max capacity of 70GB by launch, in this case well up from the max of XDCAM. |
February 1st, 2007, 06:13 PM | #19 |
Hmm...
I don't buy the flash argument. The thing is with XDCAM is that it's a convenient medium for both shooting and long term storage, and it's random-access nature makes it a lot more appealing than DV tape, obviously. Flash on the other hand is a superb short-term medium, but long term? I dunno. How many stills photographers keep their shots stored on flash? None. They all transfer them to optical media for long-term storage. Which begs the question; if you can record direct to the longer term medium, why bother with the middle-guy? Who wants to spend their evenings moving from one storage media to another when you can just eject the disk and pop it straight on the shelf? Unless flash gets really cheap - like £5 or less for 20+ Gb, and we start treating it as "disposable" media, I don't see it taking over. Nor do I see XDCAM domainating in it's current format, 23Gb just isn't enough, and the format sill a little too proprietary - but what we can say with certainly is that tape is all but dead (sorry for saying that guys!); the future is going to be a random access device of some description. Personally, I'd put my bet on optical of some kind, but I think both flash and hard disk drives will help to push the boundary. |
February 2nd, 2007, 03:57 AM | #20 |
[QUOTE=David Heath]My opinion is that the beauty of the Infinity (at least in concept) is that it is EITHER a Compact Flash camera OR a RevPro camera, depending on circumstance. CF has the solid state advantages of P2 (at a much lower price), whilst RevPro has the consumable media advantages of XDCAM. Use whichever is most appropiate for the job. Or maybe record to both at the same time - the CF version becomes the instantly available recording, the RevPro is the zero effort archive.
QUOTE] Both have their advantages, although my problem with the compact flash cards is the size. They're too small, you can hardly write the contents on the outside, which in a large organisation with large amounts of recording media going through is vital. There are lots of circumstances in which the recording has to be handed on, rather than downloaded on location. A credit card sized flash memory would be much handier and also easier to find on the desks covered in files and papers that are commonly found in production and newsrooms. Hmmmm... whatever happened to the paperless office? |
February 2nd, 2007, 05:50 AM | #21 | |
February 2nd, 2007, 06:20 AM | #22 | |
Memory Sticks allow you to write on them, so it shouldn't be a problem if the flash memory is designed to take a label. If they plan to replace tape etc., where it gets physically handed around it's something they'll have to consider. Also, you often don't have time to download on location. |
February 2nd, 2007, 06:39 AM | #23 | ||
Don't get me wrong, I support XDCAM over P2 mainly because of cost. But I feel that XDCAM will be here for awhile. It will evolve over time, but to me it's the right combination of factors including price, integrity (shelf life estimate of 50 years), length of record time (another P2 hindrance IMHO), etc. Quote:
In one sense, all formats are 'interim' because they will be supplanted at some point. But if XDCAM goes 7 to 10 years, that will be plenty for folks to get a good ROI, given the lower cost of newer cameras and decks. And that will make the freelancers who supply the networks very happy. In the end, we'll all just have to wait and see. None of us really knows for sure. |
February 2nd, 2007, 08:25 AM | #24 | |
If we assume that x networks now switch to XDCAM per year, but that the trend only lasts for 2-3 years before "Format X" comes along and everybody starts to go for that, the total number using it is then only 2x or 3x. If you only work for one client, this is largely irrelevant (you use what they want), but if you work for many it becomes very relevant. Hence the distinction between a format in use, and a format achieving high current sales. Beta still meets the first distinction, but definately not the second. |
February 2nd, 2007, 08:48 AM | #25 | |
At the moment there is a state of flux regarding the formats, although so far as delivery to broadcasters is concerned Digibeta and HDCam seem to be pretty common standards. |
