Can you use xdcam HD with Final Cut 5.0 at DVinfo.net
Old January 23rd, 2007, 09:21 AM   #1
The title says it all. Do you need 5.1 or will FCP 5.0 work adequately with xdcam hd?
Thanks for the help.
Best,
John
John Godwin is offline   Reply With Quote
Old January 23rd, 2007, 09:46 AM   #2
Using XDCAM HD footage requires Mac OS X v10.4 or later, QuickTime 7, and Final Cut Pro 5.1.1 or later ... Sony XDCAM Transfer software must also be installed to effectively access the XDCAM HD footage
Andy Mees is offline   Reply With Quote
Old January 23rd, 2007, 11:00 AM   #3
Yes, you can. In July last year I edited XDCAM footage in FCP 5.0.x before 5.1 came out. But you have a limited count of codecs at your hand. I worked under OS X 10.4.7 and XDCAM transfer 1.0
Klaas van Urk is offline   Reply
