XDcam HD Workflow Question
I have a question about Xdcam workflow..... my question is can you successfully go from start to finish on a project using Xdcam & Final Cut Pro without the PDW70/30 Deck? I mean can I film in HD 35MB, edit in FCPro and export to DVD and/or HD DVD for playback on a standard DVD Player or a HD DVD Player? Or would i need the Deck to do this? and what benefits would the Deck give?
Hey Brian,
I don't own a deck, so I can't speak to what advantages it offers, but I have shot, edited and mastered all without one. I use an F350 and have filmed a 30 minutes television show @ 35Mbps, cut it in Final Cut Pro (which is an absolute joy.. the workflow is awesome) and then mastered back to XDCAM disc. I have also used Final Cut Pro and DVD Studio Pro to make DVD versions of my edits. I know that DVD Studio Pro has HD-DVD capabilities, though you would need an HD-DVD burner to output that way. Hope that helps in some way. Jeremy Spruston |
#3 | |
Thanks Jeremy, very helpful.... i presume that your DVD versions were downcoverted to SD? what was the quality of the DVD versions? I'd imagine they were very good. |
Master back with firewire or SDI?
When you master back to the camera do you have to use SDI? I read on this forum that the firewire is for output only.
Tip |
#5 | |
So you don't need a special burner unless you need the longer running time that a true HD-DVD would give you. regards, -gb- |
#6 |
Thanks Greg, I guess you really do learn something new everyday!
Tip: Sony supplies an XDCAM Exporter (along with the Importer) that will write back to the disc using File Access Mode through FCP. Brian: For my DVD versions, yes they are downconverted into an Anamorphic DV file. They do look pretty nice, but nothing compares to the original HD signal. Jeremy Spruston |
#7 |
Hi Jeremy
Did you export an anamorphic DV version directly from FCP for your DVD, or did you roundtrip from the camera (ie re-import the finshed and exported piece via firewire, from the camera, using the camera's hardware downconversion) Cheers Andy |
#8 |
Hi Andy,
I exported an anamorphic version through FCP. It turned out pretty nice, though I still find the FCP downconversion a little shoddy. That could be because I am so used to looking at an HD source though. |
#9 |
Jeremy, there is an interesting workflow posted at http://www3.telus.net/bonsai detailing one HDV users method for producing good quality downcoversions for DVD ... it may worth a look to see whether it can be any use to your own DVD workflow
#10 |
Hey thanks Andy! That makes a huge difference in the downconversion quality. I've been trying a ton of different methods to get XDCAM downconversions to looks better but that's one of the best.
Thanks again. |
