25 to 35 mps conversion at DVinfo.net
Old November 4th, 2006, 09:24 PM   #1
Whoops! Shot a couple of discs in 25mps accidentally, and would like to render/covert them up to 35mps in FCpro, so that I can easily work with them in 35mps timeline.
When I place a 25 clip in the 35 timeline, then render, looks good. Then
I drag to bin, then drag back to timeline, it wants to see a render again!
Any way round this? I don't mind the disc space -- I just want to work with the files in the 35mps mode...
BW
Bill Weaver
Across Borders Media / Media that Matters
Bill Weaver is offline   Reply With Quote
Old November 4th, 2006, 09:33 PM   #2
You'll have to drag all the 25mb media files into Compressor, make a preset to convert all those to 35, and just wait.
A very. Long. Time.
My Work: nateweaver.net
Old November 4th, 2006, 10:02 PM   #3
How does one set that up?
Other alternative is to put selects n a 35 timeline and render, then use as a bin. But curious about the Compressor route. I don;t see even where there's starting point for XDCam HD
Bill Weaver
Old November 4th, 2006, 10:15 PM   #4
Download these:
http://homepage.mac.com/nweaver/.Pub...20Droplets.zip
Drop your original 25mbit files onto the appropriate droplet, and away you go.
Old November 4th, 2006, 10:48 PM   #5
Download these:
Thanks, Nate ---
But when I drop the file on the droplet, a little windw comes up, I hit submit, and nothing happens. What am I missing?
Bill Weaver
Old November 4th, 2006, 11:27 PM   #6
Hmm, maybe there's a mismatch on our versions of Compressor. It's supposed to bring up Batch Monitor at that point, and then dump the new files in the same folder as the old files.
Ok, let's try something different:
http://homepage.mac.com/nweaver/.Pub...sorPresets.zip
Unzip, and put the 3 resulting files in username/Library/Application Support/Compressor
Now when you open Compressor you'll have these 3 new presets under "Custom" (not "Apple").
Drag all your 25mbit media into the batch window, choose the appropriate preset for each, and then submit.
If Batch Monitor doesn't come up at this time, then your Compressor install is broken and you need to reinstall it.
Old November 5th, 2006, 12:51 AM   #7
Thanks, Mr. W...
I'll give it a try....
Bill Weaver
