#16 |
Carroll, have you tried going into the minus figures (if there are any)? Also, have you tried adjusting the Skin DTL Width option?
#17 | |
Contributor
I would submit that if the skin detail change will not show on that monitor then, even if one wanted to use that function it would be useless because it would not be detectable on display used by the customer. I've used the procedure recommended by Matthew and I have yet to detect a change. Carroll Lam |
#18 | |
I was using the HDSDI input on a Sony LMD-232WS 23-Inch LCD Monitor. But the change was very subtle. I expected a bigger change as well. Another helpful suggestion from above would be to make sure you've narrowed the skin detail width down to a more specific tone. This helps to keep everything else sharp while decreasing detail in a more specific color/tone. |
