Sync of TC & VTR(really:VDR) Control With Multiple Camera Shoots
Does any one know the exact setup and or requirements to connect 2 to 3 HD XDCAM cameras together with all having the same timecode and having the ability to start and stop the recordings of all cameras from the "master" camera?
Not sure how you would start all the cameras from one camera. Maybe if you had a wired control box that connected to the lens remote socket or lens socket you could fire off several cameras together. Timecode is simply a case of taking the timecode out from one camera to the time code in of the next with a BNC cable. The slave cameras should have the timecode set to regen and free-run. I would recommend that the master camera ran free-run timecode and that you allawys try to run the cameras for at least 5 seconds prior to starting a take to allow for pre-roll should you need to feed the edit suite using deck control with pre-roll (i.e traditionally). If you are going to use XDCAM file transfer then pre-roll is not such an issue, although it is a good habit to get into.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#3 | |
Contributor
Carroll Lam |
#4 | |
Yes you can Carroll, but without being truly synced, they will drift. This method was tried when the XL2 cameras came out. Setting them to free-run and resetting them to 00:00:00 via a common IR command. They drifted apart in short order. -gb- |
#5 | |
If doing multi-camera TC sync, make sure all of them are set either to DF or NDF otherwise they will drift apart. -gb- |
#6 | |
Contributor
Carrroll Lam |
#7 |
Starting the cameras all at once is not really what you need if you're trying to do multicam. What you need is to have all the TC on the cams match as much as possible.
If you jam sync all the cams, TC will match on all of them to the frame until one gets powered down. Then that cam will drift up to 7 frames, although in practice it's less. The way multiclips in FCP are set up this drift you'd have to fix once, and that's it. Not a biggie. If you want them all perfect, all the time, just run TC between all them and leave it. Then you don't have to worry about them all starting and stoppping at the same time...a second here or there won't slow you down in the edit at all.
My Work: nateweaver.net |
#8 |
Nate is very correct regarding "Frame Drift."
I guess just don't power down the cameras until the shoot is all done (in a studio)? Is there a device that I can hook up to all of the lenses that will start and stop the recording? |
#9 |
Various companies make wireless TC links so you don't even need cables, just one camera with a transmitter to send the TC and all recievers on all the others. More expensive certainly but if running long cable is a problem or if cameras are moving around alot it's a neat solution. As nate and others have said, starting in sync isnt really the issue but TC sync saves so many headaches.
